Base Station Won't Reset Due To Busy Cameras
One of three base stations will not connect to cameras and will not let me reset remotely.
Camera error says - Maximum of 5 camera streams are supported simultaniously. Please stop one stream before starting another camera stream. However, there are no cameras streaming on this base station or the other two.
Base station error when trying to restart says - your camera is busy and cannot restart.
Remove cameras on that base and do a reset ( hold in the reset button for about ten sec till the front leds flash... ) , let it come back online and resync cams
The cameras are four hours away. Are there any remote procedures that I can try?
Yes, in SETTINGS, of the base you can try RESTART..that's it
You can't reset the base station when the cameras are "busy". Even if you turn the camera(s) off, the base station will tell you they are busy and can't reset.
Did you ever get a resolution to this? My system is doing the exact same thing!
Power cycle the base.
If you really want to reset the base (which isn't the same thing as a power cycle), press the reset button until the LEDs flash amber. Remove ALL devices in Settings, My Devices. Use the Add Device button to add the base and sync the cameras. Verify your firmware versions compared to what's posted in the Release Notes section here.
