Model no vm53330
hi I set every thing up and was working,then I pushed deactivation on my iPhone and now nothing,I have nothing I have reset and sync the cameras and still nothing,what Di I do
if you 'deactivated' the base you have to re-install it before anything will work.
( add base; it should repopulated with serial number )
