Is this the camera's problem or something else. My other camera has no problem. This didn't happen until the new app. addition.
Did you check/edit your modes?
I have 2 cameras with this unit and I synkt them at the same time and did the same for both. One works and one doesn't.
Sorry for the late reply.
Need details. Syncing is only the first step. You didn't say whether you checked your modes or what issues you're still having or how you've tried to troubleshoot.
I did the same set-up with both cameras at the same time. That includes mode, settings, synking, sensitivity, and time (seconds-45) to record. I also moved the proper working camera to the position of the 10 second recorder and there is no problem.
If you can swap camera positions and the problem follows the camera, it's likely a camera problem. Create a trouble ticket for possible RMA.
How do I creat a trouble ticket?
See the Support link at the top right? Use it and look for Contact Support on that page. Many choices.
Thank you so much for your time and effort. It's good to know there is someone to help with this system.
None of the suggested solutions have solved the problem. Kathleen is to call me at 10:AM this morning.
Benn,
Were you able to resolve this issue with the help of the Arlo Support Team?
Please let us know!
