I have an arlo base station (vms3230) with 2 security cameras.Since last hour the base internet light is amber meaning that there is not connected to internet .Of course the base is connected to internet and all other devices which are connected to the swith they are working properly.I have tried turn off and turn on the device,new ethernet cable and switch ethernet port but without luck
Any advice ?
Everthing is ok now.The problem was from netgear network
i have the same issue, must be arlo network issue
Try to connect a wired device to your router/modem and make sure the wifi is disabled on that device. Check if you can access internet when device is connected wired to your router/modem.
Good to hear 🙂
