The mode tab won't appear on our Android apps any more. The only tabs visible are now Devices and Library.
The Mode tab worked yesterday for me (Google Pixel 2), and for my wife this morning (Google Nexus 5).
I can log into https://arlo.netgear.com/#/modes and change the modes.
I have restarted my base station, and reinstalled the app. Why would the modes disappear during the day without us changing anything? Is this another server issue at your end? We've had this problem before with an Arlo outage causing hours of confusion, and no notification of downtime.
The Arlo engineering team is currently investigating this issue. I will post an update when I have more information.
I am having the same problem. I already rebooted the base and I tried logging off and on. With this many user's having the same problem it could only be the app. Can the moderator bring this up to the attention of Arlo?
Logged on and tried to access mode button to arm cameras and found that it was missing.
Me too. I unarmed yesterday, but today, the mode option is not present for me to use to arm system.
@JamesC what's the progress from the engineers? I assume there were some action that caused this to happen so have a rollback to previous state/version of code been evaluated?
I even u installed and reinstalled. My mode is gone to
There have been times when it has been slow to appear.
Are you IOS or Android? Try and reinstall the app.
What about if you login here https://arlo.netgear.com/#/login
None of this helps, Streak2
There is a major problem with the Android App at the moment, see the other thread at https://community.netgear.com/t5/Arlo/Mode-won-t-appear-in-Android-app/td-p/1565043
Same issue here. Samsung Galaxy A5 running Android 7.0. Arlo App v2.4.12_20632. The mode tab is not available at all. Have tried restarting phone, clearing application data/cache and uninstalling/reinstalling from the play store with, but still no mode funtionality showing in the app.
Same problem as every prior commenter. Mode tab on Android app disappeared on both my devices starting yesterday. Tried the usual stuff, cycled the base unit, uninstalled/reinstalled app. Clearly, the app is broken and should be fixed. Netgear: Please Fix.
Arlo support claim that the "engineering" team are "diligently working for a fix". The bugs within the pervious releases of the Arlo app don't show much diligence or testing, for example geofencing no longer working.
They also said "Just like any other security systems, we do admit that our cameras has many flaws."
So far I have had no problems with the camera's, it just the shockingly bad software (mobile app)!!!
Yesterday the Mode tab was missing from the app. It only shows Device & Library. I uninstalled the app, restarted the phone and forced close the app 3 times. Restarted the base twice and the mode tab is still missing. It's available on the website but not on the app. Why is this happening? And how can I fix this?
Yesterday there were two posts started about this issue. One has completely dissapeared and the other was moved the the Arlo board, even though it was posted on the Arlo Pro board. Many people on android reporting to have the same issue. Yesterday I did not have the issue, mode tab was there and functioning. Today my mode tab is also gone. I'm on android 8.0.0 using a Samsung S8.
On the one post that was moved to the Arlo board, @JamesC, the community manager posted and said the arlo engineers are working on it.
Luckily for me I always leave mine in armed mode and use smartthings to turn the cameras on and off. But for anyone who disarmed and cannot arm today, this is an issue. Hopefully they fix it quickly.
It's hard to say. I've had no problem using multiple devices ever since this issue was first reported.
Tried deleting and reinstalling app but still only have device and setting tabs.
Its my account...no sharing issues. Any help is appreciated,.
Have you tried a browser? Even a mobile browser should work if set to use the desktop version. Yes, it's a workaround.
As a workaround, try using a browser. You can use a mobile browser if you set it to use the desktop version of the site.
