Mode easier access
Hi, I have set up a few custom Modes. They work as expected. Activating them, however is a bit tedious. I have to open the app, wait, change to Mode, tap on my base station, choose the mode I want. On the Modes screen there's the option to arm/disarm all devices. Is there a way to create a shortcut at least on the Mode screen? Maybe even on the start screen right above the list of devices that I get when I start the app?
Thanks, Cyd
Thanks, Cyd
On iOS you can hold down the Arlo App Logo for a native Arm/Disarm shortcut if that helps.
No, not really. The question was about custom modes. Maybe any thoughts on that? I take it is not an option these days, otherwise you would have given the instructions. Do you know a timeline for this feature to be available? Thanks in advance.
