Mode changes to "disarmed" by itself
Having just installed two Arlo Q plus cameras recently, one camera keeps reverting its mode to Dis-armed, currently I'm using a schedule to arm them overnight but one camera arms itself correctly whereas the other camera keeps reverting back to dis-armed and not recording .
Checking the firmware, they are both up to date with the latest and running the same version - 1.8.3.2_17494
Searching these forums, this seem to be an identical issue from back in 2016:
https://community.netgear.com/t5/Features/Mode-changes-to-quot-disarmed-quot-by-itself/td-p/1087617
Any help appreciated
Fastest thing would be to remove the camera from Settings, My Devices and resync fresh. If it still happens, open a case with support here.
loopee,
Are you using a custom mode in the schedule or the default "Armed" mode? Check the rules for the mode being used and make sure everything is set up correctly.
Try to check the MODE of your system if it is set to SCEDULE or ARMED. Because if it's under schedule, camera will really follow the settings it was set.
Hi James
I'm using the scheduling function to arm/disarm the cameras, as can be seen below
This only affect the one camera
loopee,
Have you set up the schedule picture for both cameras? Are they identical?
