I have eight cameras and only seven show up in the all motion on mode. In the camera area all eight show but no green running man. I can take a picture with the camera that does not show up. I used cell phone to record this problem. What happened to the camera?
Check your rules and modes - it's possible that the one camera is somehow not selected.
In rules only 7 cameras show. In the mode area only seven cameras show. In the camera area eight cameras show and I can take pictures and video manually. Tried sync with base station still the same. All firmware is the same in all eight cameras. All eight were working for a week until yesterday.
korybrown,
It sounds like the rule for the eighth camera was deleted. We'll call this affected camera, "Camera 8". Try recreating the rule by navigating to Settings, Rules and then clicking "Add". Then set up if motion is detected on Camera 8 then record on Camera 8. After you have done this be sure to click "Save" in the top right hand corner. After you have created the rule, navigate to your active mode and make sure the new rule is active by clicking on it. If done correctly the rule text will turn green with a green check mark next to it.
Hope this helps!
