Magnetic mounts
Will the magnetic mounts securely hold the cameras in high wind/stormy conditions?
I have had no issues with these mounts or the old Vuezone mounts.
yes, so far
Using the wall magnetic mount for outdoors...I have seen that it holds up to the wind ect....but will it rust as it is a magnet. Is it an alloy that resists corrosion?
I've seen no corrosion. The magnet is in the camera, not the mount but both surfaces are covered.
