Movement question on Arlo Camera
I have my Arlo camera set up outside at the end of my driveway to catch anyone that is driving down. My issue is that the camera seems to not catch the car driving down, I will get an alert and I will go to see and it will be the car already parked and someone getting out of it. Why is it that it doesnt catch the motion of the car driving down the driveway? Do i need to set something up differnt in my settings? Thank you
I would try and adjust the sense level of the camera, and make sure the motion is more across the view ( like 45 degrees ) than straight on.
Big trouble is if the back ground has traffic, you may get to the point of a lot of false triggers...it's a balance
Also if you could post a pic of the scene, we may be able to give better recommendations
