MR1100 support gutted?
Hello all,
Dug out some of my Arlo cameras and an MR1100 Nighthawk. I can set up the Nighthawk and enable the Arlo base, but I'm unable to set up or even find the MR1100 in the Arlo app.
Did support for the MR1100 get discontinued and it just not be documented anywhere?
I never saw an announcement but that would be on the Netgear site (Arlo is separate). Basically, there were a couple of abortive attempts at integrating Arlo into Netgear equipment that failed miserably due to the need for Arlo updates to be installed much more frequently than router updates. Consider it dead in the water.
