I JUST ORDERED THE TWO CAMERA KIT. IF I GET A THIRD OR FORTH CAMERA, DO I HAVE TO GET ANOTHER BASE STATIONS.. HOW MANY CAMERA'S CAN I CONNECT TO MY KIT WITHOUT GETTING ANOTHER BASE STATION?
You can have 5 cameras with your base station on the free basic plan. To add additional cameras, up to 10 you need to subscribe to the premiere plan.
Greg
garyboilers wrote:snip... IF I GET A THIRD OR FORTH CAMERA, DO I HAVE TO GET ANOTHER BASE STATIONS.. HOW MANY CAMERA'S CAN I CONNECT TO MY KIT WITHOUT GETTING ANOTHER BASE STATION?
The extra cams will sync with the base stations just like you did the first two. ( up to 5 , 10 or 15 max depends on service level )
It's supposed to work just as with the first camera. Press the Sync button on the base briefly (don't hold it down) and then on one camera. Should be blinking blue LED on the camera and that's all. If you see anything else like amber LEDs something is wrong. Try again and post here.
Hoang,
Were you able to get your second and third cameras synced? Please let us know if you're continuing to have trouble. We would be happy to assist!
When you press the Sync button on the base, be sure it's only a brief press. Don't hold it down. Does that help?
No! My other 3 cameras won't sync at all.
I'd try a factory reset first. Reactivate and try again and check the 3 LEDs on the front - they should be lit and green.
