  • 1 Reply
  • 2535 Views
vorsicle
My Arlo keeps showing a low batt warning however the batts are new.  All above 3.2 volts.
Rebooting both devices (cam and router) don't help.
First , you didn't say if they are OEM or rechargeables... some rechargeables will show as low.
New OEM batteries should be at 3.2v when tested.
So, I would pull the batteries you tested as good, and try them in a second camera ( or put another new set in the same camera ) and see if the problem follows the camera or batteries.
If it is just the one camera, then contact Netgear with a trouble ticket for possible replacement
