Longer (extended) camera mount
  • 1 Reply
  • 6838 Views
ChuckDurn
I have an ideal mounting location near my front door which would be greatly improved if a camera mount approximately 12-18" in length was available. (A portion of the wall juts out, and I'd like to place the camera on a specific side of where it juts out.) The only "close" mount I could find is a telescoping mount from Panavise, but it only comes in black and I would prefer a white (or at worst, beige) color. Is anybody aware of a mount which is both attractive and of that length? Thanks in advance for any suggestions.
There are many lengths mounts availabe as any one with standard thread will work...
like one of these kits where the sections screw into each for the size needed;
http://www.alldataresource.com/Mascon-TV12-12-Expandable-Camera-Mount_p_185865.html?utm_source=bing&...
http://www.amazon.com/VideoSecu-Ceiling-Bracket-Camera-Adjustable/dp/B000X23I22/ref=sr_1_62?ie=UTF8&...
