Rules
  • 3711 Views
RockinFWB
I accidentally deleted 1 camera off rules menu. How do I get it back on
KristynM
RockinFWB,
You could simply add another rule for the camera.
  1. Settings > Rules > Add (Located on the top right)
  2. Name the Rule
  3. Select the camera that you want motion to be detected on. Then select it's sensitivity.
  4. Select the camera that you want the recording to be done on. Then select the length of the recording.
After you are done creating your Rule, don't forget to click on Save. The article What are rules & how do I create them? will provide you a detailed outline of how to create rules.
Looking forward to your response.
Regards,
KristynM
Arlo Support Team
Paycheck
I removed a camera from Rules by hitting delete Rules , how do I get it back .
Paycheck,
You can recreate the rule as KristynM describes in her post above. Alternatively you can log in to your Arlo account, navigate to Settings, System Settings, and click Camera Order. Remove the affected camera and then resync the camera with the base station. This will recreate the default rule for this camera.
