how do i delete arlo from my laptop
You really don't have to do anything but delete your browser history as the pc version is accessed via a browser ( no app )
If you mean IOS or android, go to settings/apps and delete the app ( varies per device )
Thanks for the info I appreciate it. Now I have another question why do my batteries run down so quick I use 123 lithium turn on the monitor 8:pm and turn it off at 7:am
It depends usu on how much you record.... heavy record times = short battery life
