  • 2 Replies
  • 3160 Views
REB1149
VMB3000 Neat gear arlo . This has my login locked , I cant remove it , support says a virus , but what that means is i dont know , Somebody will i hope . I have sucessfully changed name and got a confirmation
{{'login_label_forgot' | i18n}} {{loginError}} {{'help_label_support' | i18n}} {{'password_reset_title_reset_lost_password' | i18n}} {{'password_reset_label_new_password' | i18n}} {{'info_registration_account_password' | i18n}} {{'password_reset_label_confirm_new_password' | i18n}} {{'error_validation_password_mismatch' | i18n}} {{'activity_submit' | i18n}} {{'activity_cancel' | i18n}}
App or browser?  Try the other if you've only tried one.  It would be good to try a different system if you suspect a virus.
If it only happens on one device but not another, try reinstalling the app or flushing the cache on the browser (or use a different browser). Of course, making sure you're virus-free is also mandatory.
REB1149
Solved , I took Chrome browser , no Explorer would work . Thanks you much for the reply !
