try and reboot the base with the power button
im having same problem anyone have uk phone number
Did you check the Contact Support link at the bottom here?
Mikeski,
If you navigate to Settings > My Devices, do all of your cameras and base station show here?
Do you see the same behavior when viewing from a different client?
Lou25uk wrote:
Yes have clicked link and selected my country but then does not give any information
Just tried this with the UK and Australia and a number pops up below where you select the country.
I think I have the same problem. I have had Arlo for over a year with very few issues. For some reason I started losing cameras from the base over the past few weeks. Today I finally started from scratch and deleted all 8 of my cameras and did a hard reboot of the base station. I have been able to sync two Arlo Q cameras and 3 arlo wireless cameras. However, I have 3 cameras that will not show up on my account. I changed all batteries prior to re-syncing. I get the fast blinking blue lights for ten seconds and everything should be good. Nope. When I check the App or online, the cameras do not appear.
I have read many articles and troubleshooting tips but have not been able to find an answer or possible fix. To repeat, the cameras sync but do not show up online on my desktop, IPad or Iphone apps.
I really liked my Arlo system and was contemplating getting the Arlo Pro but after these issues and reading how SOOOO many people are having issues, I'm not so sure. I am trying to avoid contacting Arlo Support becasue previous contacts took awhile to get a response. Its probably a simple fix but I am not seeing it.
PLomaglio,
The rapid blue LED should be an indication that the camera sync was successful. Consider logging out of your account, clear your browser cache, and log back in. Are you still unable to see the cameras after syncing?
						Accessories4
						Activity Zones1
						Amazon Alexa1
						Apple HomeKit2
						Apple TV App9
						Applications mobile et en ligne1
						Apps4
						Arlo Go3
						Arlo Mobile App722
						Arlo Pro36
						Arlo Pro 21
						Arlo Q (Plus)3
						Arlo Smart196
						Arlo Web and Mobile Apps18
						Arlo Wire-Free30
						base station1
						Batteries529
						Before You Buy924
						Can't view cameras live at all1
						Dépannage1
						Détection de mouvements1
						Features1,064
						Fehlerbehebung1
						Firmware Release Notes93
						Google Assistant1
						Hardware1
						home security1
						IFTTT (If This Then That)105
						Installation2,046
						Iphone 14 pro1
						Live view1
						Modes and Rules1
						Motion Detection2
						Object Recognition3
						Online and Mobile Apps983
						Online und mobile Apps1
						Order Not Going Through... help please!1
						Other Discussions1
						Partner Integrations4
						Security1
						Service and Storage14
						Smart Subscription3
						SmartThings71
						Troubleshooting9,083
						Videos233
						Vidéo2
						Warranty & Contracts2
