I just want to get an idea of how many users had some type of issue today either with rules on your mode not working, getting alerts with no video. Don't post problems with getting the right motion angle or mounting issues. I had a custom trigger mode set for 2 weeks where camera 1 would detect motion record and have camera 2 record. Camera 2 would detect and record and have camera 1 and 3 record. These rules worked great till sometime early today 7/20/16 when none of the activated cameras would trigger the others in the rule. I hard and soft rebooted the base to no avail. It seems to be getting back to normal now. The purpose of this post is just to get a record of how many ppl this affected not to bash. When I contacted netgear and told them a bunch of problems like mine popped up on the forums and asked if they had any server issues they said they had to confirm. I think with a web based service if they have a server or software issue they should instantly advise ppl so we don't go crazy and at least know they are working on it. Still love my Arlo!!
You guys have to handle this type of situation better. First, OWN the problem. Second, Inform the community. When multiple users report the SAM EXACT ISSUE, the system has a problem. The scripted "did you do this, did you do that" only frustrated Arlo users, inclduing myself.
Maybe PIN a topic in the community, read only, and label it "Known Issues". That way users can stay informed saving us from throwing these cameras in the garbage.
Just my 2 cents.
Hula
I couldnt agree more. I was so frustrated by tech support being told to re-start the cameras, adjust the angle etc that I actually called the retailer where I purchased them to see about returning them. If I had known I was not the only one with the problem, I could have rested a little easier.
Yep that's all you hear around here is adjust and reposition the cameras or private message a photo. Problem solved...... Really a great product to own.
@JamesC I'm having issue still, but it's with the app notifications. Everything cross records as I set but the app is giving me the same notification. Example; camera A detects motion and records on camera A and B. I then get two notifications simultaneously alerting me that camera A has detected motion nothing for camera B.
ctderek wrote:@JamesC I'm having issue still, but it's with the app notifications. Everything cross records as I set but the app is giving me the same notification. Example; camera A detects motion and records on camera A and B. I then get two notifications simultaneously alerting me that camera A has detected motion nothing for camera B.
I noticed the same thing this morning..........
Hear we go again ....
@JamesC I am also having that issue. And, I am afraid to say, one of the cameras which was supposed to cross-record this morning did not. When I pulled out of the driveway, and later, when my wife did, the camera triggered by the driveway recorded, but the driveway did not. I have adjusted the recording times so that I can know which cameras were the triggering device (record for time in multiples of 10 seconds) and which were the triggered device (multiples of 5 seconds) because the displayed alerts are wrong. This morning, it was the triggering device which did not record, but the triggered device did. Same as last week. I really hope this is not happeneing again, lol. I can live with the incorrect lables, but the cross recording issue is a real problem. Thanks for your help.
ctderek, Hula_Rock
I too am seeing push notifications arrive as you describe, thank you for the report. I will escalate this for further investigation.
Tocker30,
I have tested this and did not see the same results as you describe above. I will update the case you have open with support and escalate for further investigation.
Thank you for the feedback,
@JamesC I readjusted my modes slightly and then restarted the base station, and I no longer seem to be having issues with the cross-recording, only the duplicate notifications. Thank you for your help.
Thank tou
bmattox79 wrote:
Most first tier customer service is just read from a script, do this try that, again just tell us there's an issue and that your working on it and we will understand and wait for the fix without thinking we have an isolated issue
Yes exactly........all is left to get is "is it plugged in.....?" actually no not that.....I meant "you sure there are good batteries inside?". Please give us a break, issues we're experiencing with Arlo need to be FIXED by Netgear. How much more obvious does it need to be that endless numbers of upset users have done all that is required for proper installation and all the same problems keep getting reported over and over again?
It's a disgrace really, to be given this kind of runaround.
