Is there a way to re-sync up the cameras remotely?
Is there a way to re-sync up the cameras remotely? I have 3 cameras at a vacation home and they went offline for some reason and I will not be able to get there anytime soon. Can I restart the base and then hopefully the cameras will sync back up?
If all the cameras went off-line, then it's likely that the base is what's really offline. In that case, you likely won't see the restart control for the base.
If you do see the restart control, then that might work. But it doesn't always.
