Installing Arlo Camera on exterior of Motorhome
  • 2 Replies
  • 7139 Views
dd5087
Just received Arlo cameras for Christmas and I am installing these in a motorhome.  The camera I want to install on the exterior of the motorhome will be mounted on an aluminum exterior surface and I don't want to drill holes in this surface.  Can you recommend a weatherproof double sided tape for this installation? Obviously I will be removing the exterior camera when I travel.
The best double stick tape I've seen is 3M molding tape ( made for car trim on sides ) at most auto stores
The roll is about 1/2 " wide and I've covered the entire back of a ball mount then trimed it neat... wipe down the attachment area with alcohol so it's clean of any grease, etc and make sure it's above 50d F- (check label) ( if cold can warm the metal with hairdryer ).  Attach and let sit for day then use if directed.
To remove mount ( camera off before driving , mount alone should be fine when driving ) you take dental floss and "saw" the tape in half then clean area with tape remover ( goo-be-gone or similar ).
dd5087
Thanks, just what I was looking for.
