  • 1 Reply
  • 1066 Views
Bartley
Luminary
Luminary
I would like to know if there will be an option for a wireless indoor camera in the future. I only see the wired version. I think this would be a great option for those that would like to have the camera located where there isn't an electrical outlet and/or do not want a power cord visible. I realize I can use an outdoor camera as well.
Gary
Yes... prob the best option at this time is to use a Pro2 camera....there are many mounts you can use with it or it can just sit flat on shelf/counter/etc. For me I get bout 3 months from Pro 2 indoors.
The mount I like the best is this one ;
https://www.bestbuy.com/site/table-ceiling-mount-arlo-arlo-pro-compatible-white/6133013.p?skuId=6133...
BUT, if you can wire it to ac, the best camera now is prob the Essential Indoor cam ( newer version of Q cam ).
It uses pixel detection over PIR so it works great for detection and can be used to detect motion thru windows ( no night vision as it reflects back from glass ) It also has the shutter so you can instantly know that it is on/armed or not.
