I set up system and synced two of the cameras. The third camera does not sync.
I set up the system. Had no trouble syncing the first two cameas but the third does not sync. Tried replacing the batteries..still nothing. When I install the batteries a blue light comes on for a second. When I try syncing with the base station nothing happens....no lights at all.
Ok, if you just push the camera sync button do you get slow flash in blue of front led?
( goes away after 10 secs or so )
No lights at all. Absolutely nothing shows.
Cameras are wireless, battery operated. Not possible to plug them in. But thanks for the advice.
Contact Netgear Support for possible replacement
