  • 6 Replies
  • 3266 Views
anetnau
I set up the system.  Had no trouble syncing the first two cameas but the third does not sync.  Tried replacing the batteries..still nothing. When I install the batteries a blue light comes on for a second.  When I try syncing with the base station nothing happens....no lights at all.
6 REPLIES 6
Ok, if you just push the camera sync button do you get slow flash in blue of front led?
( goes away after 10 secs or so )
anetnau
No lights at all.  Absolutely nothing shows.
Try plugging the camera in and sync while powered. If that works it's a bad battery. If not it's a bad camera. Swap at the store or open a case with support.
anetnau
Cameras are wireless, battery operated.  Not possible to plug them in.  But thanks for the advice.
This is the Pro section so plugging in is possible. If you have the original wireless cameras, please post in the proper area.
Contact Netgear Support for possible replacement
