I put in battery for 2 hours and goes offline? Using correct battery?
I bought new batteries for my Arlo: Procell 123A 3V: I put it in and it works for approx. 2 hours and then it goes offline?? Am I usuing the correct batteries.. This Arlo uses 4 of these batteries?? Please help. thanks
Hi dorismalo,
If you're referring to the Arlo Wire-Free HD camera, you would be using CR123 lithium 3-volt photo batteries, which you can read more about it here: What kind of batteries does my Arlo camera use?
But if your Arlo camera goes offline, read this article to learn how to troubleshoot: My Arlo wire-free camera is offline; how can I troubleshoot it?
Yes, this help. It is now working. I took it offline and reset it.
Thanks all.
