I have to log in every time I'm on the Arlo Android app. Make persistent login.
Every time on the Android app I have to log in... this is hyper annoying!!!!!!!!!! Allow persistent login please.!!!!!
Hi @sgmorton,
Need some info on how to duplicate this issue, as I'm not seeing it on my Android app.
Do you explicitly log-out of the app?
1. Log in by entering credentials,
2. Use the app
3. Log out
4. Close the app
The next time you open the app, you're asked to enter the credentials again?
Thanks in advance!
