  • 1 Reply
  • 1209 Views
stone172
Help, I have good enough WiFi signal but I believe the base signal is too weak. How would I boost the base signal?
You can't... the cameras talk only to the base unit and will not work on extender
You only options are 1) move the base to a central location by either a wifi extender with etherent port ( or cable ).  2) add a second base unit ( the only true way to expand coverage area )
