I have 3 Arlo Cameras on one base station. 2 cameras are set on Motion. How do I get the 3rd camera to be on a different mode? I'd like the third one to be on a Schedule. When I go in to create a new mode, since the base is already set to Motion, that stays the same. Can I make that 3rd one different, not motion, schedule instead?
Thank you.
A few hints;
You can only have one schedule ( unless you run more than one base )
Any camera NOT in a MODE will be off.
Only ONE mode can run at a time.
So it sounds like you need to create a couple of custom modes to separate the cameras
You have as default ARMED ( all on ) and DISARMED ( all off ). With 3 cameras A, B, C,
To cover all the possible choices, you need a mode for ( tho usu less );
cam A
cam B
cam C
cam A-B
cam A-C
cam B-C
make modes for the cameras as you splt them up , like inside/outside/etc.
Thank you.
If your running a schedule, you must have all the cameras on a schedule if in use or not ( in a way they are since any camera not in a mode is off )
So you have to make a cutom mode for two of your cameras and then another for the third cam.
That way in schedule, you could run the set of two , the one cam , or all of them... just place the proper Mode into the schedule as needed
