  • 1 Reply
  • 1200 Views
lplace
I get different outcomes when I've tried for the past week to sync this second camera. At first the camera would blink amber. I did all the troubleshooting suggestions and at this point, I had seen a faint blue light. I opened the battery compartment... then closed it... and I get nothing. I didn't know if you have to wait a certain length of time before trying to resync again... so it ended up being once or twice a day I would try again. Not sure what else I could possible do?
Once or twice a day isn't right. Worst case, opening the battery door and closing it resets the camera and you try again. If that doesn't work and you can't sync (be sure you're onlt briefly pressing the base sync button - don't hold it), open a case with support.
