  • 1 Reply
  • 2413 Views
rslencak
I just set up new Arlo system including account creation and completed sync"ing cameras.  All indications are that everything worked properly except that on the "camera" page, I can't see that I have any of the four cameras that I sync'd; it's stuck on "How to sync a camera."  I have version 1.10.5.708_10299 and have power cycled and re-sync'd all cameras, power cycled base station and re-sync'd cameras.  Any help would be appreciated.
I think the version you're referring to is the app version which shouldn't have any effect.  I'd suggest doing a factory reset by using the reset button located near the power button while holding the Sync button on the side of the base.  Then sync the cameras and see if that gets you going.
