I can't locate my ARLO Library on my computer
Do you mean what you d/loaded from Arlo?? A bit lack of info in your question....
First the 'library' does not reside on you computer but in Arlo/Amazom cloud storage... To get it to your computer, you must down load the files from storage to the local computer ( where they will end up in you browser's default d/l directory )
Log in, go to Library ( bottom of screen ) go to the date, go to SELECT, pick what you want by checking off, click the d/l ... they go to the defalt dir.
