I can no longer set up a schedule for my cameras? What happened?
I have 5 cameras inside and outside the house. I've had the system for a couple of years now, and I used to have the cameras set for any kind of action at night time in particular. Worked great. Now I can no longer set up any schedule.
When I go into the setting portion and then try to set the timing, for example from 9pm till 6am, I cannot press the SAVE button after that. I would like to be able to set the outside cameras up for motion etc at night time in particular, but I cannot find out how to do it.
Do I need to do the $10 a month subscription to access it? Any help would be great; otherwise I have no idea why I have these cameras if I cannot get to use them for my own safety?
Thank you!
You don't need the subscription....
But, when you use the schedule, AND you go thru Midnight , you MUST break up the schedule into two parts.
In your case 9pm to 6am;
it would need 9pm to 1159pm( covers the whole min ) and on next day 12 midnight to 6am
Try that, let us know
Also to run just the outside cameras and not the inside, you need to Create a CUSTOM mode ( add a mode )
Split up the cameras as needed, create the new mode, with first camera and save... then go back and edit it for adding additional
