Showing results forÂ
Hurry up and sort servers out 5 days now ðŸ˜
Getting really peed off can't log in can't turn cams off on sort it out
7 REPLIES 7
I've had no issues with servers since the day of issue.
Lucky you it's in certain areas
Have you opened a case with support?
Tonstar1,
There are no server issues to my knowledge. What are you seeing that is indicating an issue?
Open app says getting status for sooooo long ca t arm disarm etc
Something's going on I'm
Having similar issues
Tonstar1, lee76
This sounds like a display issue, do you see the same behavior if you log in and view from the web client on a different device (laptop, PC)?
