Has anyone had luck finding just the mounting disc for the outdoor brackets vma4000b? After 6 years they are becoming brittle and shattering when removing camera to replace battery. I bought the bracket vma4000b for the first two that shattered but really don't want to buy the whole thing if I can find just the mounting disc
Thanks in advance for any help
Message 1 of 2
618
Arlo doesn't sell parts like that. However, the easy thing to do is to check for outdoor camera mounts that use the standard 1/4"-20 thread and just replace the mount.
Message 2 of 2
592
Message 2 of 2
593
