  • 1 Reply
  • 1447 Views
Thuebner
Has anyone had luck finding just the mounting disc for the outdoor brackets vma4000b? After 6 years they are becoming brittle and shattering when removing camera to replace battery. I bought the bracket vma4000b for the first two that shattered but really don't want to buy the whole thing if I can find just the mounting disc
Thanks in advance for any help
Arlo doesn't sell parts like that. However, the easy thing to do is to check for outdoor camera mounts that use the standard 1/4"-20 thread and just replace the mount.
