You can't download CVR video. You must view it and use a screen capture program to be able to store it locally. Kind of a pain but it does work.
CVR is cloud-based. You can view the video and use screen capture software to manually record the stream as it's viewed which will record the audio, too. You could use a tape recorder or an audio recorder that will capture what's on the stream as you view it.
You need to read the FAQs here to understand the various features. Normal recordings are time-limited while CVR is a continuous stream of video and audio. The major difference is that the CVR stream can't be downloaded - it would be huge. You have to view it using the Arlo website or app. While viewing, you can use screen capture software to record it locally for your long-term usage. It will record both the video and audio.
I happen to use paid software for screen capture but a quick Google for screen capture software gives you options. Here's one:
https://www.pcmag.com/news/349410/how-to-capture-video-clips-in-windows-10
It sounds like you need to contact a local person for help with this. It's well beyond the scope of these forums.
