I have a third app (Home Assistant) that uses my primary admin account to show cameras. This results in logging out my phone as the Home Assistant takes over every 10 second.
I have added a new user and want to use this in Home Assistant but it seems the first user is cached in Arlo and it keeps using this login even if I change the user in the app
How do I somehow remove the acess for the Home Assistant app to Arlo ?
Micvan,
It's not clear what the issue is that you're experiencing.
Are you saying you're logging in to the Arlo Secure mobile app using the same credentials on multiple devices?
No, I have granted a 2factor access to my account logging in from Home Assistant
But that means, it logs out of my phone and when I try log in from the phone it just keeps logging me out, as the Home Assistant "wins" the battle
So i made a new account and tried to use this from Home Assistant - however, it seems that the Arlo has approved the Home Assistant forever now, and wont change the user from the device. So I guess that it somehow has a token granted access somewhere and I need to clear this and start over... Is this possible from Arlo somewhere?
