  • 1 Reply
  • 1568 Views
Dmars
After setting up with a password, Id like to change to a fingerprint. How do I accomplish this?
JessicaP
Hey @Dmars,
Depending if you are using iPhone or Android, you can go to Settings > Profile and choose "Log in with Touch ID" or "Enable Login using Fingerprint."
You can read the following below for more info:
