Read the FAQ here on this topic. You make changes in your modes and rules.
What are modes and rules and how does Arlo use them?
You can adjust the length of the video recording from a minimum of ten seconds to a maximum of two minutes.
Just another user
When I initially did the set up it asked how long of a record length which I set for 10 secs I would like to change to 30 secs but can't find that option settings anywhere now
Did you read the various FAQs here on this and similar topics? These settings are in your modes and rules which are found under the Mode tab.
