- 2
I've had multiple issues trying to get Arlo to work. It performed properly for 3 days and then the problems started. The base unit would constantly lose the Internet connection and on the control panel (on the web) it would say offline. But I'd get motion activation notices on my smart phone anyway. Strange.
Next, pulled batteries from cameras and paper clip reset base station. Only one camer will re-sync and base station still won't play
So I deactivated the base station from my account...probably the wrong thing to do!!! Now I cannot figure out how to re-associate my base station to my account.
Ideas welcome, and thank you.
I do not have a "add a base staion" , now what do I do?
Drea2003, alpet
The engineering team has identified and resolved this issue. Are you still experiencing this behavior?
Hello,
I don't have the option to add a base station down the page of subscription !?
DonaldLaborde,
You can add a base station to an existing Arlo account by clicking the "Add Device" button on the cameras screen. This feature was implemented in the latest UI update. Please let me know if you have any issues with this!
You're resetting improperly. Since the beginning of the year update has us using only the reset button, not the reset and sync buttons together. Try again.
Tell us what steps you're taking, what the LEDs are doing, and maybe post a screenshot of your display so we can see what you're seeing.
I'm following the steps suggested (Setttings, Subscriptions, etc) at the start of this thread. The LED's are fine.
You do realize that a lot has happened/changed since this thread started a year and a half ago. Without knowing exactly what you've done, all we can do is guess.
And you haven't told us the problem and what you're tried to do to fix it.
It's the economy!
If you do a Factory Reset when you login to your account the "add a base station" has been moved to the first page along with the other selections NOT at the bottom of the devices page.
You are starting over, Right?
So it makes sense it will be on the first page.
- 2
