How re-associate my base station with my account? (I deactivated it...)
  • 1 Reply
  • 4744 Views
jarvis1960
DarrenM
Sage
Sage
Hello Jarvis1960
What you need to do is log into your Arlo system click settings then click Subscription then the last option on the right will be add a base station you will want to click that. From there is should auto search for the base station or you can enter the serial number in found on the bottom of your base station.
Let me know if you have any questions
DarrenM
Arlo Team
