How o I adjust setting for "Best Picture Quality"
  • 1 Reply
  • 5558 Views
pevgeo
Noticed on Board that Picture Quality can be adjusted, where do I find this setting, unable to locate.
DaneA
Hi pevgeo,
You may set you Arlo cameras to Best Video setting.  Go to Settings > Camera Settings then select a camera then on the Power Management section, select Best Video then apply the changes.
Upon checking our system, let me inform you that both of your Arlo base station and cameras are not on the latest firmware version.  I recommend you to upgrade the firmware version of both.  Kindly access these articles below as reference guides:
How can I trigger my Arlo system to update its firmware?
https://community.netgear.com/t5/Arlo-Knowledge-Base/How-can-I-trigger-my-Arlo-system-to-update-its-...
What do I need to know about Arlo camera firmware updates?
https://community.netgear.com/t5/Arlo-Knowledge-Base/What-do-I-need-to-know-about-Arlo-camera-firmwa...
How do I update my firmware when I am prompted that a firmware update is available?
https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-update-my-firmware-when-I-am-prompted-...
Let us know if you have further concerns.
Regards,
DaneA
Arlo Team
