How does this solar panel thing work? the picture shows no cables to hook it up to the camera plus the camera has no place to plug in a supply. I am tired of having to get the ladder out every 3 weeks to change batteries. The only cameras you have the plug in are for interior use only, if anyone is in the house the camera will only be recording me shooting them. Can you update your site to show wiring diagrams as to how the power goes from solar cell to the camera that has no place to plug anything into it. I about to chunk the whole thing.
The solar panel will NOT work on the original Arlo cameras...
They will work on the Pro/Pro2 and the Ultra ( different panel for the Ultra )
You need the Arlo Pro & Arlo Pro 2 cameras with the square rechargeable batteries... the original Arlo with the Cr123 batteries won’t work
