  • 2 Replies
  • 4269 Views
  • 2 Likes
randp1
Just got the surveillance camera and would like to change the video duration  from 10 seconds to longer, possibly 20 or 30 seconds.  I can't find a settting to do that, but read that it could be done.
manfredz
Hero
Hero
Go into Mode
Go into the Profile you are using
Go into edit for the cam whose recording length you wish to modify
Go into record video
Change the record length
Go back
At the bottom hit Save
This same question was just answered yesterday as well as numerous other times.
Spend some time looking through posts as well as the FAQ and you'll learn a lot.  There's lot of things you can do to tailor the Arlo cams to your intended use.
manfredz
Hero
Hero
Go into Mode
Go back
randp1
Thanks so much.  Was looking in Settings rather than Mode.  I actually did search and didn't find anything but obviously was not in the correct spot.  Just figuring this out as I just got it today.  So far so good.
