Just got the surveillance camera and would like to change the video duration from 10 seconds to longer, possibly 20 or 30 seconds. I can't find a settting to do that, but read that it could be done.
Go into Mode
Go into the Profile you are using
Go into edit for the cam whose recording length you wish to modify
Go into record video
Change the record length
Go back
At the bottom hit Save
This same question was just answered yesterday as well as numerous other times.
Spend some time looking through posts as well as the FAQ and you'll learn a lot. There's lot of things you can do to tailor the Arlo cams to your intended use.
Go into Mode
Go back
Thanks so much. Was looking in Settings rather than Mode. I actually did search and didn't find anything but obviously was not in the correct spot. Just figuring this out as I just got it today. So far so good.
						Accessories4
						Activity Zones1
						Amazon Alexa1
						Apple HomeKit2
						Apple TV App9
						Applications mobile et en ligne1
						Apps4
						Arlo Go3
						Arlo Mobile App722
						Arlo Pro36
						Arlo Pro 21
						Arlo Q (Plus)3
						Arlo Smart196
						Arlo Web and Mobile Apps18
						Arlo Wire-Free30
						base station1
						Batteries529
						Before You Buy925
						Can't view cameras live at all1
						Dépannage1
						Détection de mouvements1
						Features1,070
						Fehlerbehebung1
						Firmware Release Notes93
						Google Assistant1
						Hardware1
						home security1
						IFTTT (If This Then That)105
						Installation2,046
						Iphone 14 pro1
						Live view1
						Modes and Rules1
						Motion Detection2
						Object Recognition3
						Online and Mobile Apps983
						Online und mobile Apps1
						Order Not Going Through... help please!1
						Other Discussions1
						Partner Integrations4
						Security1
						Service and Storage14
						Smart Subscription3
						SmartThings71
						Troubleshooting9,083
						Videos233
						Vidéo2
						Warranty & Contracts2
