How do i extend just one camera beyond the intial Base??
How do i extend just one camera beyond the intial Base?? I have a Location that is 500 plus feet away and has no Internet access
is there an extender that will transfer the signal to the base
Not without a long Ethernet cable and a repeater (Ethernet cables can't exceed 300 feet so you'd need 2 cables and a switch to pull this off). WiFi extender should wouldn't be as good.
The Arlo Go may be a better fit since it's battery operated and uses cell service.
