How do I change the camera name and also how do i set camera for recording
Set the name in Settings, My Devices, your camera. Edit the Name section.
By default, the Armed mode is used when first installing the system. Your cameras in the Devices tab should show the running men to be black, not gray. To check what mode is in use as well as to modify and create your own custom modes, use the Mode tab, click on your base and poke around. Actually poke around through the whole interface to get familiar with the system.
To change the name of the camera, just go to SETTINGS and first line for camera , type in a new name and save
As mentioned, ARMED is the default mode to use to turn on motion detect
