  • 4 Replies
  • 10494 Views
  • 7 Likes
joethetoolman
How do I change the Video recording time (Length)?
manfredz
Hero
Hero
go into mode
go into the mode/profile you are using
go to the cam you want to change mode for/edit
go to video settings and adjust slider
repeat for other cams you wish to adjust
hit back
at bottom hit save
and you should be in business
manfredz
Hero
Hero
go into mode
hit back
at bottom hit save
TLJ
i was told to look under mode and there was nothing there to make any changes to
manfredz
Hero
Hero
Surprised you couldn't find any of the other posts that explained it step by step but here goes:
Go into the mode you are using
Edit for the cam whose recoding length you wish to change
Under record video you will see the slider to change the length
Hit back
repeat foe any other cams you also want to change record length of
hit bck
And here's the important step
At bottom, maybe even necessary to scroll down hit SAVE or your change will be for nothing
Missing one important step. Dunno why folks don't do this on their own but click on your base in the Mode tab to see your modes. You can have multiple bases and Q cameras to choose from in one account but a typical user will only see the one base.
