Improve Firmware Download
  • 4 Replies
  • 7159 Views
Triumph250
Please extend the amount of time for for downloading firmware updates. I (and others) have slower IP connections and the firmware updates are timing out. It appears that the download is attempted for ~60 seconds before failure. Increasing this to 240-300 seconds should be more than sufficient.
The effort to remove cameras, disconnect the base station, relocate to a location with better IP performance, allow updates to take place and reinstall system every 6 months for every update is becoming burdensome.
Customer support likes to quote a minimum upload speed but, that should not have anything to do with the downloading of firmware updates.
Is there a specific reason to limit the download time? Can the time limit be extended?
Triumph250,
Who is your ISP and what is your download/upload speed?
Triumph250
AT&T
download: 1.1-1.3 Mkbs
upload: .20-.30 Mkps
Speeds like that are very definitely a problem. Firmware updates and recordings will both be problematic.
Triumph250
My recordings, upload, recorded viewing and live streaming are all decent enough.
The problem I am having is with the firmware updates timeing out. The first question is, is there a specific reason why the timeout period is so short? Second, can the timeout period be extended for firmware updates? I am sure that the capability to change this exists, if not at the costomer level, then on the software side.
That us my request for system improvments,
