  • 1 Reply
  • 12814 Views
JonDarcey
I have two cameras on the system.  Is it possible to have only one of them "armed" as far as detecting and recording movement? I only want one camera to do this and the other not too.
Thanks much,
Jon
Yes. You just need to create your own mode with only one rule for the camera you want. There are good FAQs here for that but basically explore the Mode tab, click on your base and check it out the Armed mode. Don't modify it but use it to understand. Then create your own new custom mode. Once created, set the new mode to be active and you should be all set.
